Hi everyone,
I've read several threads but couldn't find the answer I'm looking for.
I'm trying to protect my circuit the same way the attached schema works (using PMOS)
I've read this one:
http://www.electro-tech-online.com/...ion-of-input-power-with-low-voltage-drop.664/
and this one
from other threads
However I'm having a specific question regarding the voltage of my own circuit.
I want to support 10-26v as VIN (in fact 12v to 24v but with some margin).
I plan to use either UA78M05CDCYR or LM2937IMP-5.0/NOPB to go from 12v-24v to 5v.
My problem is that Vgs using a P-channel in this case can theoretically be at some point 0 - 26v (-26v) or 5v - 26v (-21v) and most of the Pchannel I find in the package I want are max VGS -20v.
1) Do you believe the case Vgs (-26v is possible?)
2) In the case I have 25v supply, we will be @ Vgs -20v, do you think it's a safe practice to stay close to max limit?
What do you recommend me to protect from inverse polarity?
Thanks in advance for your help!
I've read this one:
and this one
