reverse polarity for DC motor
Discussion in 'General Electronics Chat' started by Phayilboy, May 9, 2011.
  1. Phayilboy
    May 7, 2011
    OK as you can see i am new to these forums and i have a problem that has been adressed many times before (yes i did bother to look :D)
    I have a 4.8v mini servo which I blew the controller board after messing about (I think I wired it wrong and blew the cap on the internal control board thing)and have recently removed it and connected the power directly. I want to be able to move the motor in both directions and after some quick research found that reversing the polarity was the way to go about doing this. My understanding of this is that quickly changing the polarity massively strains the motor and therefore wondered if it is at all possible to create a circuit that not only reverses the polarity but creates a short delay long enough for the motor to stop and then turn in the opposite direction, or in some other way stops the motor before reversing the polarity.
    thanks in advance
    PhayilBoy
  2. tom66
    May 9, 2009
    2,613
    214
    Although the motor is not strained massively by polarity reversal one thing that is, is the circuit.
    Think about it: the motor is spinning normally. You decide to reverse it. Very quickly the motor goes from full speed to nothing and back to full speed (but in reverse.) Where does all the energy go? What will happen is the motor will produce a large spike of voltage (100V+) when this happens, usually enough to damage sensitive driving electronics. So you usually "brake" the motor, by connecting its terminals to a small resistor, converting the kinetic to heat, before speeding it up again.
    N.B. Generally, this is not required for small motors. Larger motors, definitely. But for smaller motors, I would just use a H-bridge. Remember to include flyback diodes if your H-bridge doesn't have them.
    Phayilboy likes this.
  3. Phayilboy
    May 7, 2011
    Thanks for the help
    Yes Using an H bridge is what I am currently doing (Built onto a DPDT switch). Would it be possible to build an H bridge that I can control the changeovers with a pot, possibly transistor based or something not using a straight forward switch
    PhayilBoy
