reverse polarity electrolytic caps
Discussion in 'General Electronics Chat' started by richbrune, Jan 30, 2009.
  1. richbrune
    Thread Starter Senior Member
    Oct 28, 2005
    106
    The attached drawing has V3 as a 12volt to 0 volt square wave. I'll try to post the netlist.
    I'd like to know if this is a bad idea, and if there's a problem with the polarity of the 4.7 uf cap
    Thanks, Richard Brune
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    If you put a reverse polarity charge across a polarized electrolytic capacitor, you will most likely destroy it in very short order.
    You can get non-polarized electrolytic capacitors.
    You could also use two 10uF polarized caps back-to-back.
    Or better, you could use a poly cap that is not polarized. Poly caps have lower leakage than electrolytics, along with very good frequency response.
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The easy way out is to obtain a bipolar capacitor, or else to use two 10 uF electrolytics in series with two terminals of the same polarity in common.
  4. richbrune
    Oct 28, 2005
    106
    So I am getting reverse polarity form this circuit?
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Have you run the simulation on it? At least the DC analysis part?
  6. richbrune
    Oct 28, 2005
    106
    Test Point V2 goes from 10volts to 0 volts, but I'm not good enough with these things to tell if the polarity at C2 is reversed
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    I was wondering about that the other day, won't one or the other be distroyed?
  8. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Nope, it's a strange thing about back-to-back electrolytics. Hook 'em up with both + or - terminals connected, and they act like a non polar capacitor.
  9. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    One also gets the bonus of doubling the working voltage. (Put high value resistors in parallel with the caps if taking advantage of this.)
    Of course, one halves the capacitance.
