reverse polarity digital logic
Discussion in 'General Electronics Chat' started by relicmarks, Apr 22, 2008.
  1. relicmarks
    Thread Starter Active Member
    Oct 13, 2006
    355
    What can cause the output to in a digital chip to have the reverse polarity when its not suppost too?
    Like its suppost to be +5 volts but its output is - 5 volts , what can cause this ? any examples please?
    What should i test for that would cause this?
  2. mik3
    Feb 4, 2008
    4,846
    63
    what chip is it? what power supply do you use? Maybe you measure the voltage with the probes of the voltmeter in reverse:)
  3. relicmarks
    Oct 13, 2006
    355
    all types of digital logic chips
    If the input signal is pulsing from zero voltage to +5 volts and the output is reversed polarity when it shouldn't be what causes this please?
  4. mik3
    Feb 4, 2008
    4,846
    63
    are you sure you measure it in a correct way? I think black probe of the voltmeter is inserted in the red pin of the voltmeter and the red probe in the black.
    is your supply voltage from 0-5 V only?
  5. relicmarks
    Oct 13, 2006
    355
    Yes i am measuring the correct probe polarity
    is your supply voltage from 0-5 V only? yes
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    On your voltmeter/DMM, the black lead should be plugged into the COM jack, and the red lead plugged into the V/Ω/mA jack.
    Your black test lead should then be connected to the digital circuit's ground.
    About the only way you would see a negative voltage in a digital circuit would be if an output were driving an inductive load that had a damaged or missing reverse-EMF protection diode, or perhaps a switched capacitor network.
    If there are overdriven linear ICs such as op amps in the circuit, you might see phase reversal (ie: latch-up), but not polarity inversion - unless there is the aforementioned inductive load or switched capacitor network.
  7. flubbo
    Member
    Apr 21, 2008
    25
    The only digital logic I've ever seen going from 0 to -5 volts is Emitter Coupled Logic.
    What kind of chips are you using?
  8. relicmarks
    Oct 13, 2006
    355
    where specific voltage levels applied to the inputs of a digital function cause corresponding voltage responses on the outputs
    Truth char using voltages:
    A B Y
    0 Volts 0V +VCC
    0V +VCC +VCC
    +VCC 0V +VCC
    +VCC +VCC 0Volts
    74HC86D chip " positive logic"
    Pin 1 is +VCC 5 volts
    Pin 2 is the input for the digital signal (toggling state) square waveform
    Pin 3 is the output
    The output is Positive polarity square waveforms
    74HC86D chip "Negative Logic"
    Pin 1 is "Ground"
    Pin 2 is the input for the digital signal (toggling states) square waveform
    Pin 3 is the output
    The output is Negative polarity square waveforms
    Questions:
    1.) How and why did the output convert from Positive logic to Negative logic?
    2.) How else can i convert Positive logic to Negative logic without using a inverter chip?
  9. kubeek
    Sep 20, 2005
    4,691
    806
    Negative polarity doen´t mean -5V on the output.
  10. relicmarks
    Oct 13, 2006
    355
    What does negative polarity mean then?
  11. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Since you don't have a -5 supply, the negative polarity must mean that the output is inverted. Like an AND gate outputs a high when the inputs are satisfied, and a NAND gate outputs a low when the inputs are satisfied.
    If you are actually seeing a negative output on a 74HCxx chip, then either you're using +5 as the measuring reference, or your o'scope is running with the INVERT switch active on that channel.
  12. relicmarks
    Oct 13, 2006
    355
    1.) Whats the difference between TTL inverted VS TTL polarity?
    Yes im actually seeing a negative output on the 74HCxx chip , the circuit does have a +5 supply and a -5 supply
    But the way the 74HCxx chip is reversing the polarity doesn't use the -5 supply at all, it just uses the ground and +5 volts on the inputs to reverse the polarity on the output
    I'm guessing since the circuit uses a bipolar power supply +5 ,ground, -5
    Then you can reverse the polarity on any digital logic chips output by changing the ground and +5 volts on the inputs to any logic chip ? so the output flips the polarity?
  13. mik3
    Feb 4, 2008
    4,846
    63
    Positive logic means the high is 1 and the low is 0 and negative logic means the high is the 0 and the low is the 1
  14. kubeek
    Sep 20, 2005
    4,691
    806
    Oh, sorry, there should have been Neagtive logic, insted of negative polarity.
    Meaning the same as inverted logic (or even inverted polarity in this case), 5V instead of 0V and vice versa.
    Edit: I see I am a bit too late
  15. relicmarks
    Oct 13, 2006
    355
    Inverter= Positive logic means the high is 1 and the low is 0 and negative logic means the high is the 0 and the low is the 1
    This is what a inverter does in digital logic
    Negative logic is different on the output on the oscilloscope you will see the squarewaveform pulses -5 volts NOT +5 volts they will be flipped to the - negative polarity
    INput is +5 volts pulses (positive logic) converts to -5volts ( negative logic )
    How can you do this ?
    why would designers use Negative logic or Inverted logic?
  16. Caveman
    Apr 15, 2008
    471
    You are being extremely unclear in this thread. First of all, try using the quote button because it is difficult to tell what you are saying vs. what you are just repeating.
    Now, it sounds like what you want to do is to drive a digital logic chip in a funky way. From the point of view of the logic chip, low (logic 0) is when an input or an output is close to the V- input (pin 7). And high (logic 1) is when an input or output is close to the V+ input (pin 14).
    So if you want to drive the chip with -5V connected to pin 7 and GND(0V) connected to pin 14 of your 74HC86D, then the chip will call -5V = logic 0, and 0V(GND) = logic 1.
    If you connect between +5V and -5V, then you should never drive 0V in because you should never drive middle voltages. This ain't analog, it's digital so stick to high or low. +5V is logic 1 or high, and -5V is logic 0 or low.
    Got it?
  17. relicmarks
    Oct 13, 2006
    355
    Positive logic:
    1.) High= +5 volts
    2.) Low= ground zero volts
    Positive "inverter" logic
    1.) High= ground?
    2.) low= +5
    (Because it had a inverter after the logic chip) so it inverted the high and low states
    Negative Logic:
    1.) High= ground
    2.) Low= negative -5 volts
    Negative "inverter" logic
    1.) High= negative - 5 volts
    2.) Low= ground
  18. relicmarks
    Oct 13, 2006
    355
    Bipolar Logic:
    1.) High is +5 volts
    2.) Low is -5 volts
    3.) No ground or middle voltage
  19. mik3
    Feb 4, 2008
    4,846
    63
    does your circuit has a dual power supply? i mean +5 and -5 V?
    Can you tell me what chip is the inverter?
  20. relicmarks
    Oct 13, 2006
    355
    does your circuit has a dual power supply? i mean +5 and -5 V? YES
    Can you tell me what chip is the inverter? there is no inverter
    They use the 74HC86D as a inverter or polarity converter
    It takes +5 volts input but outputs -5 volts so its a polarity converter
