Reverse Polarity Circuit
Discussion in 'The Projects Forum' started by rubicon99, May 17, 2012.
  1. rubicon99
    Apr 19, 2012
    46
    Hey I'm looking for an IC or a circuit that will have no voltage drop. I am inputing a 12-24 volt DC into a circuit. A simple diode will do the trick but there is about a .7 volt drop. Not a big deal but I need that input power for another part of the circuit. Rather not use a bridge rectifier cause it wastes more power.
  2. mcgyvr
    Oct 15, 2009
    4,787
    973
  3. gerty
    Aug 30, 2007
    1,154
    304
    Are you looking for reverse polarity protection?
  4. rubicon99
    Apr 19, 2012
    46
    Yes I am... even if its an ic with minimal voltage drop.
  5. gerty
    Aug 30, 2007
    1,154
    304
    If you cannot stand the voltage drop of a series diode, you can put a reverse biased diode across the power terminals. That would of course be a dead short when connected wrong and must be fused. Otherwise you can opt for mcgyvr's suggestion, which is better than a reversed diode in my opinion as there is less chance of burning something up.
  6. BSomer
    Member
    Dec 28, 2011
    433
    106
    In that case, what mcgyvr has pointed out is one of the best solutions. MOSFETs have a very low on resistance so there will be minimal voltage drop across them. They also can handle a lot of current, which is better than the typical diode used for protection. I recall there was a video posted on YouTube showing how to use a P-channel MOSFET as reverse polarity protection. I think the author of the video was afrotechmods or something like that.
  7. kubeek
    Sep 20, 2005
    4,687
    805
  8. BSomer
    Member
    Dec 28, 2011
    433
    106
    Yup. That is the video. :)
  9. BJT_user
    Member
    Oct 9, 2011
    35
    8
    Diode... and a small relay.
