Reverse output
Discussion in 'The Projects Forum' started by manuel09, Aug 24, 2014.
  1. manuel09
    Aug 29, 2009
    15
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    When you say "reverse", are your reversing a motor? If so, you will need a DPDT relay or an H-Bridge.
  3. manuel09
    Aug 29, 2009
    15
    Mike
    space at stair too small and led only 5v 150mA then i prefer to use a mosfet only,
  4. MikeML
    Oct 2, 2009
    5,451
    1,066
    I still do not understand "reverse". Can you post a block diagram of what you are attempting to do?
  5. IcedFruits
    Member
    Jan 15, 2014
    84
    he means that ebay tool gives o/p of 0v when it senses something. otherwise the o/p rests @ 5v.
    he wants o/p in reverse order. i.e. 0 under normal conditions, 5v when sensing stuff. :D
  6. manuel09
    Aug 29, 2009
    15
    This sensor output feed to mosfet
    standard infra red distance sensor "when met object = 0V otherwise 5v",
    then i want "when met object =5v otherwise 0V".
    sorry i dont understand how to post a pict.
  7. Alec_t
    Sep 17, 2013
    5,971
    1,135
    You need an inverter (e.g. consisting of a single transistor plus a couple of resistors) between the sensor and the mosfet gate.
  8. djsfantasi
    Apr 11, 2010
    2,902
    878
    To add pictures to your posts, see this blog entry.
  9. MikeML
    Oct 2, 2009
    5,451
    1,066
    Try this circuit:
      File size:
      183.7 KB
      14
  10. manuel09
    Aug 29, 2009
    15
    thank you mike
