Reverse Engineering
Discussion in 'Off-Topic' started by debe, Dec 22, 2010.
  1. debe
    Sep 21, 2010
    955
    185
    Hi guys, is it ok to ask for help on this Forum to reconstruct a circuit that is no longer manufactured & is patent has probably long expired. The circuit is for an Ign module that replaces Ign points on older engines. The patent was taken out in 1979 No 4163437, it was desighned & built in Australia. (for small single cyl engines)
  2. jpanhalt
    Jan 18, 2008
    5,699
    909
    AAC has a good distributor. You don't need to post for each cylinder. ;)
    John
  3. maxpower097
    Feb 20, 2009
    795
    388
  4. debe
    Sep 21, 2010
    955
    185
    All fixed maxpower its been shifted to Projects.
