Reverse Engineering a Transformer
Discussion in 'The Projects Forum' started by amspurge, Jan 23, 2016.
  1. amspurge
    Jan 15, 2016
    48
    I'm in the midst of a new project and I'd like to reverse engineer a transformer without destroying it. Anyone know how to do this? I know that the primary and secondary winding count is a critical factor (or the ratio, at least), but are there any other characteristics I should pay attention to?
    Thanks!
  2. amspurge
    Jan 15, 2016
    48
    Also, this is for a resistance heating project where I'm essentially shorting out a piece of metal to heat it. If there's anything I should know about special transformer properties in regards to the application, please let me know.
  3. ISB123
    May 21, 2014
    1,240
    531
    Iron core size
    Transformer will get destroyed if continuously overloaded.
  4. amspurge
    Jan 15, 2016
    48
    The transformer will only be on for 1-2 seconds each cycle (cycle about every ten seconds). I take it that heat buildup in the transformer will be the issue... how do I overcome this? Larger gauge windings?
  5. ISB123
    May 21, 2014
    1,240
    531
  6. Lestraveled
    May 19, 2014
    1,957
    1,218
    Do you intend to rewind this transformer??
