Reverse DC motor and then forward again
Discussion in 'The Projects Forum' started by cv935, Jan 21, 2010.
  1. cv935
    Jan 21, 2010
    I need help with a set up for a forward reverse motion DC 3 to 6 volt motor.
    I will be useing the motor to go back and fourth between 9 and 3 O clock.
    Like wipers on a car.
    The motor needs to be quiet and be able to lift about 8 onces and have atleast a 1.5 inch shaft with a flat side. The speed between 3 and 9 should be 1 second.
    Can someone help me find these parts and get this project on the road?
  2. Bernard
    Aug 7, 2008
    4,231
    414
    How far is weight lifted. does travel speed need to be uniform? Why lhe long shaft?
  3. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
    Would guess you need a radio control type servo motor, probably a high power one. I would use a uc to control it.
  4. hobbyist
    Aug 10, 2008
    773
    62
    1. H-bridge, for motor direction controle.
    2. limit switches to detect end of arc sweep.
    3. timing circuitry to run the motor at set speed. (pulse width modulation, to controle speed)
    4. geared head motor.
    Since I design only with transistors, and no IC's, I might try to design this from discreet components just for the fun of it. If I do I'll post it in this thread. But I have other hobbies to attent to right now.
  5. KMoffett
    Dec 19, 2007
    2,584
    234
    cv935,
    Can you explain the whole project? Reversing a motor from full speed at 1 second intervals is going to be hard on the motor. There may be other ways to achieve your goal...if we knew what that was. It might be easier to solve your problem...than solve your solution. ;)
    Ken
  6. hobbyist
    Aug 10, 2008
    773
    62
    KMOFFET, brings up a very good point.
    You may be able to do it with a geared head motor, running continuous in one direction,
    With mechanical linkages to reverse, at a set point.
    That would be the most feasable, way of doing it, that way you got continuous torque, with no abrupt turning motor speed and direction.
  7. cv935
    Jan 21, 2010
  8. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Well, you're going to need something like a windshield wiper motor & transmission.
    Using rubber mounts will help to quiet it down.
    A hobby motor/servo just won't have the torque necessary.
  9. Bernard
    Aug 7, 2008
    4,231
    414
    I cast my vote for continuous rotation. Rack & pinion for a bunny ride? I have used cut timing belt for for both. I just messed up & used Quick Reply
  10. Bernard
    Aug 7, 2008
    4,231
    414
    Now I have to think of 10 words, must be the late hour and advancing years.
