Reverse Biasing Photodiode Techniques
Discussion in 'General Electronics Chat' started by baseball07, Jun 16, 2010.
  1. baseball07
    Thread Starter Active Member
    Apr 24, 2007
    39
    Hi, I have a question about reverse biasing a photodiode. Is it the same thing if you apply a positive voltage to the cathode, or a negative voltage to the anode? Can either be done and will still be reverse biasing the device? Thank you.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Measuring voltage is dependent on the reference point. A reverse bias does mean that the voltage across a device is the opposite to a forward or operating bias.
    With respect to the cathode, the anode will be more negative. With respect to the anode, the cathode will be more positive. With respect to circuit ground (the conventional reference point), the cathode will be more positive than the anode, and the anode less positive than the cathode.
