Reusing Computer PS
Discussion in 'The Projects Forum' started by jaack, Sep 16, 2013.
  1. jaack
    Sep 13, 2013
    I need a high power negative power source. I can use a 2nd ps for the + side. For a Hi power amplifier would like to use a computer power supply but how do I separate the grounds to +12 & +5 lines. Are schematics available for supplies. Been electronic tech for years, so can unsolder the relevent parts, if i could figure out what to separate.
    Anyone reuse a ps this way?
    Jaack
  2. Experimentonomen
    Member
    Feb 16, 2011
    331
    46
    Not worth it where there are psus available that has dual isolated outputs that can be wired as desired.
    I'd use a iron transformer though for a audio amp.
  3. Shagas
    May 13, 2013
    802
    74
    Not sure I understand , you want a dual power supply for your power amplifier right?
    How Hi of a power are we talking about?
