Return from Intterupt - I'm using PIC16F877A C language for my project
rocker123uk
Joined Dec 6, 2015
33
im doing my final year project and need help about a part in interrupt . I'm using PIC16F877A for my project . I'm using C language for programming and MikroC as my compiler . I'm trying to find a way so that when the microcontroller exits the interrupt service routine , it should go back to the starting of the main program rather than return to the address in the main program where the stack pointer is showing . In other words , the program counter should reset to the beginning of the main program .
IS there any way to do this ? if yes, please share. Thank you!
jpanhalt
Joined Jan 18, 2008
11,087
Are you wedded to that chip? If you can use an enhanced mid-range that has STKPTR, then it is relatively easy.
Here is a related thread from another forum on that point: http://www.electro-tech-online.com/threads/erasing-return-address-of-call.145388/#post-1228915
I only do assembly and have seen the need to return to a known point, but it really is not easy, unless you can access the stack.
John
Edit: An alternative is to set a flag in the interrupt and then check that flag in routines that are not stable to an interrupt (e.g., something that depends on an outside timed event).
dannyf
Joined Sep 13, 2015
2,197
What you are trying to do can be done. But it is difficult to do, especially in a high level language like C.
However, a better question for you is why do you want to or have to do that? Countless mcus work in the field flawlessly without your kind of return mechamism.
If I were you, I would seriously rethink about your approach.
Papabravo
Joined Feb 24, 2006
21,225
Only way I know is to keep interrupts disabled and force a watchdog RESET. This cleans up the stack and all the peripherals as well.
Picbuster
Joined Dec 2, 2013
1,047
set flag in interrupt when it returned to originated point pickup flag and go to main.
John P
Joined Oct 14, 2008
2,026
I was going to say what Papabrovo says--what you're trying to do is equivalent to resetting the processor. But as Dannyf said, what's the point of this? Nobody else in the world has a need for it.
Come to think of it, how about hara-kiri? Maybe the processor can trigger its own reset pin via an external output. I've never tried it, but I don't see why it wouldn't work.
rocker123uk
Joined Dec 6, 2015
33
thanks guys for the comments, if that would be difficult then i would prefer to stay away haha. but could i use a pushbutton to jump to a specific loop in a program with many loops , for example if rb0=1 jump to main while loop.
jpanhalt
Joined Jan 18, 2008
11,087
Yes, at least in Assembly that is possible. For example, I use a push button on a project to force re-calibration. I see no reason that can't be done in C.
John
dannyf
Joined Sep 13, 2015
2,197
Yes. But no of that requires returning to a particular point from the interrupt.
Whenever you run into something that's "unnatural" to a chip, you may want to rethink your approach.
What you are asking for is an unstructured goto spaghetti producer.
That's almost universally a bad thing in programming unless its for a fatal error handler.
For C you could use the structured goto statement called a 'switch' with a simple interrupt or event driven finite-state machine to design good embedded software.
http://www.barrgroup.com/Embedded-Systems/How-To/State-Machines-Event-Driven-Systems
