retrieve code from hex file in 8051
Discussion in 'Programmer's Corner' started by madhun, Jan 2, 2006.
  1. madhun
    Jan 2, 2006
    Hi All
    I need a support if its possible to retreive a code in c from hex file while working on 8051 microcontroller based project. If yes, howz it possible.
    Looking forward to your help. Thanks in advanc.
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    What you will need is a disassembler program. Try googling with the keywords disassembler and 8051.
    You will probably only be able to knock it back to Intel assembly language format.
    Reverting back to C-language while feasible is a bit of a stretch.
    hgmjr
