Retransmission with AT89C5115
Discussion in 'Embedded Systems and Microcontrollers' started by jauco03, Nov 19, 2015.
  1. jauco03
    Nov 19, 2015
    I am completely new working with microcontrollers, I have to us one for solving a problem. I would like some advice about what kind of source should I check for commands for retrasnmitting with the AT89C5115 and at the same time put an OUTPUT HIGH as a control signal to enable transmission in another component.
  2. nerdegutta
    Dec 15, 2009
    2,565
    805
    Hi.
    I think you need to explain a little bit more about your project.
    What are you transmitting?
    How will you transmit?
    The better the explanation, the better answers... :)
  3. jauco03
    Nov 19, 2015
    Thank you!
    I am recieving a packet of bytes in UART, I need to retransmit it in UART and write HIGH in an output. This because I am using a max489 to covert to rs485, since I need to enable and disable the driver of the max489 and the device I am controlling doesn't have control I am using the at89c115 for this purpose.
