Resurection
Discussion in 'The Projects Forum' started by CRY&PRAY, Feb 20, 2014.
Thread Status:
Not open for further replies.
  1. CRY&PRAY
    Jan 6, 2014
    84
    It's always me!, resurrecting this old post, how can i run this amp with a car battery? i would like to get a +-12 v or more from the battery to feed this amp, i'm going to build it in a small enclosure to drive my woofers in the car.
    http://forum.allaboutcircuits.com/showthread.php?t=94344
  2. Experimentonomen
    Member
    Feb 16, 2011
    331
    46
    Havent you read the forum TOS ? No automotive modifications/enhancements allowed, this includes plugging a cellphone charger into the ciggylighter plug in the dash.
    *waits for thread closure*
  3. wayneh
    Sep 9, 2010
    12,394
    3,246
    My understanding (could be wrong) is that accessories that plug into the socket are not restricted unless they have other obvious safety problems. They do not modify the stock vehicle.
  4. tcmtech
    Nov 4, 2013
    2,117
    1,753
    I would have to agree that this does not sound like a direct modification of any part of an actual vehicle or its electrical system.
    By my reasoning its modification of something that can be put in a vehicle but then most every project ever discussed here could be put in a vehicle too.
    I say let the thread play out.
  5. CRY&PRAY
    Jan 6, 2014
    84
    okay, sry, well the question is: how to mod that amp for a 12 v power supply (12-15v swing). I've made that amp by myself but i cannot get ti running in single rail :(
  6. tcmtech
    Nov 4, 2013
    2,117
    1,753
    I would say that usings simple push pull power oscillator to make a DC to DC converter would be the simplest way to get the +- 12 VDC you need.
  7. R!f@@
    Apr 2, 2009
    8,792
    771
    OK . This time you SHOULD read this.
    Metalmann and RichardO like this.
  8. bountyhunter
    Sep 7, 2009
    2,498
    507
    The simplest and cheapest way would be to buy a second battery.... they don't cost that much. You can get cheap motorcycle lead acid batteries for about $30 with about 15 A-hr capacity.
    Of course, an even simpler way is to buy a car amp which has a switcher built in so it only needs 12V to run on. They are dirt cheap too.
  9. Experimentonomen
    Member
    Feb 16, 2011
    331
    46
    But a commercial caramp will be an automotive modification as you have to hack into the electrical system by drawing a fat cable from the battery, through a fuse, through a hole in the firewall and back to the trunk to the amp.
  10. R!f@@
    Apr 2, 2009
    8,792
    771
    Installing car amps is in no way an Automotive modification.
    Drilling holes in the firewall is a no no!.
  11. CRY&PRAY
    Jan 6, 2014
    84
  12. tcmtech
    Nov 4, 2013
    2,117
    1,753
    Yep that's the sort of circuit I am talking about. Just wind your secondary to the voltages you need.
  13. Georacer
    Nov 25, 2009
    5,151
    1,266
    Lighter plug circuits are allowed in an automotive environment in AAC, but we all know that a subwoofer amplifier draws much more current than what a car lighter plug can supply.
    You'll modify the car circuitry and we all know it. Prove me wrong, if you want.
    I'll probably close this thread soon, I'm just waiting for a convincing counter-argument.
  14. R!f@@
    Apr 2, 2009
    8,792
    771
    Still Wiring a cable from battery to car amp is allowed.
    But no drilling holes any where.
  15. Experimentonomen
    Member
    Feb 16, 2011
    331
    46
    If you are lucky enough that there is already a existing hole in the firewall to run the cable through.
  16. Georacer
    Nov 25, 2009
    5,151
    1,266
    No, tapping onto your car battery is not allowed.
    As I said before, car-related circuits are allowed only if they don't tap onto the car electronics at all or merely plug onto the lighter plug.
    Tapping from the DC voltage of the battery directly is not allowed.
  17. bountyhunter
    Sep 7, 2009
    2,498
    507
    The lighter plugs will typically handle upwards of 25A. I remember I had a rear window defroster that plugged in that sat in the back. Ended up getting the plug hot enough that the plastic deformed.:p
  18. bountyhunter
    Sep 7, 2009
    2,498
    507
    I really doubt that. Most cigarette lighter outputs are fused at 20 or 25A which is close to 300W continuous. Sub amps have ridiculously high (and often FICTIONAL) power ratings but don't operate anywhere near those numbers for average power. large caps near the amp would handle the peaks. IMHO, even ground shaking loud music would probably never exceed about 25W RMS (continuous) power.
  19. tcmtech
    Nov 4, 2013
    2,117
    1,753
    Easy way around that. Wink Wink Nudge Nudge. :p
    The OP just has to say he has a ex police car that came from the factory with the high current feeder line to the trunk that the some of the police package cars had for the additional high powered electronics they stuffed back there.
    A buddy of mine has a old highway patrol car of which he asked me what I thought the big wire was for he had in the trunk. Best guess was it was the power feed for the old patrol car electronics. That's my theory and I am sticking to it! :D
  20. bountyhunter
    Sep 7, 2009
    2,498
    507
    A lot of them had a second battery in the trunk. They also had a high output alternator.
Thread Status:
