Resources - Calculating speaker enclosures
Discussion in 'General Electronics Chat' started by cumesoftware, Sep 15, 2007.
  1. cumesoftware
    Thread Starter Senior Member
    Apr 27, 2007
    1,330
    11
    Did some "extensive" research and found some satisfactory calculators on the web. Here are the links:
    http://www.bcae1.com/spboxnew2.htm
    Gives several construction details. Also has a very useful calculator to decide if a woofer or sub (or the speaker with the greatest piston effect) should be applied in a sealed or vented (ported) enclosure.
    http://www.mhsoft.nl/ (main page)
    http://www.mhsoft.nl/spk_calc.asp
    Calculates the internal volume of an enclosure (sealed or vented) and also determines the frequency response. A very good calculator.
