Resonator Driver Circuit
Discussion in 'The Projects Forum' started by pal114525, Aug 5, 2015.
  1. pal114525
    Jul 3, 2015
    46
    Please see the attachment.
    The attached circuit is a resonator driver circuit.
    In this circuit simulation, I am using LTSpice.
    I am getting the current through the inductor as sinusoidal. But, the voltage across the inductor is not sinusoidal in nature.
    Is it a problem of the circuit or problem of the simulator?
    Thanks & Regards.
  2. pal114525
    Jul 3, 2015
    46
  3. alfacliff
    Dec 13, 2013
    2,449
    428
    its not a problem, its just the nature of inductors, they try to hold the current through them constant, so the voltage across them varies.
  4. pal114525
    Jul 3, 2015
    46
    Thanks for your valuable feedback.
    I've also checked it on breadboard and the voltage across the inductor is not a sinusoidal. It is a distorted waveform from sinusoidal waveform.
    Any suggestion for getting a pure sinusoidal wave across the inductor would be highly appreciated.
    Thanks & Regards.
