Resonant frequency formula manipulation.
Discussion in 'General Electronics Chat' started by arthur92710, Dec 1, 2007.
  1. arthur92710
    Thread Starter Active Member
    Jun 25, 2007
    307
    If i know L F and Pi(its a blueberry pi) how do I find C?
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    You have all of the variables in hand except the one you want to calculate. It should be a simple algebra problem from there.
    hgmjr
  3. arthur92710
    Jun 25, 2007
    307
    So would it be (f*2pi)^2 =1
    .........................L ......=C
    But how do i get rid of the 1 over the c?
    Should i just use the reciprical of both side?
    ......L .....=..C
    (f*2pi)^2
    Right?
  4. mozikluv
    Jan 22, 2004
    1,437
    am about to give you the correct formula, but i guess it won't help. why dont you put reasonable values on the original formula and work your way backwards and see if you get the correct values thru your reformulation.:)
  5. hgmjr
    Jan 28, 2005
    9,030
    214
    More like this:
    C=\frac{1}{L(2\pi f)^{2}}
    hgmjr
  6. cheddy
    Oct 19, 2007
    87
    1/x=1/y
    multiply both sides by x*y
    x=y
  7. arthur92710
    Jun 25, 2007
    307
    well thanks...
