Hi Guys,
A difficult couple of questions to explain.
Say I have a loop antenna that is DC short circuit,
cut or tuned with a capacitor to resonance at f,
and in the other hand I have a clear carrier at f.
f might as well be 10MHz but could be anything.
Now say I take the carrier at f, and perfectly null every tenth peak, so now measured over one second the new f is 900kHz, but it's got a flat spot after every 9 peaks, and it's peaks
are still aligned with the original 10MHz carrier.
Q1: Am I still holding a resonant antenna?
Q2: if the answer was yes, what if a team of monkeys select another random quantity and location of peaks to perfectly null, and the result f is maybe 812kHz over a one second interval,
but the peaks left are still aligned with the original 10MHz wave.
Cheers, Art.
Cheers, Art.
