Curiosity Testing:
I want to use two Current Transformers in series with a conductor in a loop to see how hot it can get by inducing AC current (1,000 amps and higher). However, one Current transformer will be fed from one source and the other from another. The first CT from first source I am allowed to get to resonance (pull less current from source/induce more current) if I only used it in the loop by it self.
Now that I have the second CT (rated the same) in the loop and from and second source, I am getting crazy numbers in the primaries. I am sure that I am generating some voltage across the terminals of the second CT, but if I raise simultaneously they seem to "level off" judging by CT primary currents.
I am wondering if there is a way to tune (reach resonance) with such a set-up with possibly two sources slightly out of phase? Both sources are capable of putting out same voltage. Does the second CT act as a load to loop? Does it also act as a load if I short the secondaries? Does the size of conductor act as a load?
The purpose is to put out more current on loop with half the primary value on each CT. Any suggestions?
