resonance in rlc circuits
Discussion in 'General Electronics Chat' started by joshpig, Jan 26, 2016.
  1. joshpig
    Jan 26, 2016
    Hi!
    If you want to find the resonant frequency for the voltage and current in a load (load is a combination of resistor, capacitor, inductor), in a circuit which has another capacitor and inductor. Would you use just the components outside the load, or include those in the load in the equation 1/(2pi)(LC^1/2).?
    I'm not sure if I've explained this very well but we shall see :))
  2. Dodgydave
    Jun 22, 2012
    5,159
    772
    The resonant frequency is when Xc = Xl,
    joshpig likes this.
  3. ErnieM
    Apr 24, 2011
    7,442
    1,628
    You need to work out an equivalent circuit where there is but a single resistor, capacitor, and inductor.
    Then Dave's doggy formula works perfectly.
    joshpig likes this.
  4. SLK001
    Nov 29, 2011
    852
    243
    Resonance is like what Dodgy said. The frequency of the resonance is derived as follows:
    joshpig and Dodgydave like this.
  5. The Electrician
    Oct 9, 2007
    2,301
    339
    It all depends on your definition of resonance. For example, see this page for the three common definitions of resonance: http://hyperphysics.phy-astr.gsu.edu/hbase/electric/parres.html
    Your circuit is not exactly like that one, but the given definitions of resonance will give different results when applied to your problem.
    Which definition of resonance will you use?
    joshpig likes this.
  6. joshpig
    Jan 26, 2016
    Thank you for the fast responses :)
    I am just trying to find the frequency at which current flowing through the load and the voltage across it to be in phase, now i was guessing that this is the resonant frequency as that is when the circuit is purely resistive? is that correct?
    And is Xi/Xc referring to the impedance ?
  7. Dodgydave
    Jun 22, 2012
    5,159
    772
    Xl and Xc are the reactances(AC resistance) of the inductor and capacitor,your circuit has a v+ symbol, is it a dc supply?
    joshpig likes this.
  8. The Electrician
    Oct 9, 2007
    2,301
    339
    You said that your "load is a combination of resistor, capacitor, inductor". Show the circuit of the load in detail. Together with the additional L and C you showed in post #1, the expression for the frequency at which the load current is in phase with the load voltage can be determined.
    joshpig likes this.
  9. joshpig
    Jan 26, 2016
  10. Brownout
    Jan 10, 2012
    2,375
    998
    You have to consider all reactances. However, you can simplify things a little by considering only the circuit to the left (initially) and making a thevinen equivalent.
    joshpig likes this.
  11. The Electrician
    Oct 9, 2007
    2,301
    339
    If you derive an expression for the imaginary part of the impedance seen by the source, and plot it vs. frequency, there are 3 frequencies in the vicinity of ω = 20k for which the imaginary part is zero. Those could be considered resonance frequencies.
    joshpig likes this.
  12. joshpig
    Jan 26, 2016
    Wow brilliant thanks! I would love to see how you did that, if you have that derivation to hand it would be great to see it?
  13. The Electrician
    Oct 9, 2007
    2,301
    339
    Here you go:
    Here's a zoomed in view of the crossing at ω = 21778.3
    joshpig likes this.
  14. The Electrician
    Oct 9, 2007
    2,301
    339
    To get some more insight into the behavior around resonance, let's plot both the real part (blue) and the imaginary part (red) of the impedance:
    The real part becomes very small at the lowest and highest resonance frequencies. At the middle resonance, ω = 21778.5, the real part is 8.46 ohms, a more reasonable value. The resonance there is the useful one. It's a fairly high Q resonance but the external inductance was treated as ideal.
    Here's the calculation of the value of the real part at the 3 resonances:
    joshpig likes this.
