Resonance Frequency!
Discussion in 'The Projects Forum' started by ThapeloCornelius, Sep 26, 2013.
  1. ThapeloCornelius
    Sep 25, 2013
    7
    How can i create resonant frequency using LC circuit (parallel or in series) and using DC supply , and how can i measure for resonant frequency using oscilloscope?
  2. #12
    Nov 30, 2010
    16,685
    7,327
    You can not make a circuit that resonates at zero frequency (DC).
    However, when you first connect the DC supply, the pair will respond with a short (time) oscillation. You can use an oscilloscope to look at the fluctuations and might be able to find the time interval. That will lead you to the resonant frequency.
  3. ThapeloCornelius
    Sep 25, 2013
    7
    Thanks.
    So you saying i can get a resonant frequency if i supply my circuit with AC?. If so, can i use the oscilloscope to see the signal?
  4. #12
    Nov 30, 2010
    16,685
    7,327
    Yes, and yes.
    However, you will see the signal best if the AC you supply is the same frequency as the resonance.
  5. ThapeloCornelius
    Sep 25, 2013
    7
    Thank you for your time.
    The thing is I am doing a project which i have to use the IGBT for switching, so i wanted to create resonance so that the current in my LOAD will be AC but drawn from DC supply.
  6. Dodgydave
    Jun 22, 2012
    5,153
    770
    Work out the resonant freq from the formula if you know the inductance and capacitance,F=1/6.484x root LC
  7. wmodavis
    Oct 23, 2010
    737
    150
    A series or parallel resonant circuit is just that, a resonant circuit, whether any voltage AC or DC is applied or not.
    To determine the resonant frequency you either have to calculate it (if you know the inductance and capacitance values) or measure it by applying an exciting voltage, usually by applying a variable frequency signal to the circuit, and using an o'scope or RF voltmeter as an indicator.
    In the olden days we used a grid dip meter to determine resonant frequency. A GDO is simply a variable frequency oscillator with a meter that will indicate a 'dip' when the oscillator is tuned through the resonant frequency
  8. MaxHeadRoom
    Jul 18, 2013
    10,841
    2,519
  9. Ramussons
    May 3, 2013
    562
    92
    Are you on to Induction Heating? The technique used is different.
    Ramesh
  10. w2aew
    Member
    Jan 3, 2012
    219
    64
    adam555 likes this.
  11. bountyhunter
    Sep 7, 2009
    2,498
    507
    In general, resonance occurs when capacitive reactance equals inductive reactance.
  12. ThapeloCornelius
    Sep 25, 2013
    7
    @Ramesh, Yes Im on induction heating, can you help with the technique used?
  13. Ramussons
    May 3, 2013
    562
    92
