Resonance and impedance matching
Discussion in 'General Electronics Chat' started by The Electrician, Jan 12, 2016.
Thread Status:
Not open for further replies.
  1. The Electrician
    Thread Starter AAC Fanatic!
    Oct 9, 2007
    2,301
    339
    RRITESH, can you calculate the voltage appearing at node 3 in this circuit?
    Wendy likes this.
  2. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    OK, As the circuit is at resonance mean both Xc and Xl are out of 180 phase cancel each other.
    the total current wil be E=I*R
    I=10/5=2Ams
    so, Exl=2*30=60V i think
  3. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    right?
  4. Hypatia's Protege
    Distinguished Member
    Mar 1, 2015
    2,850
    1,317
    Yes, albeit, strictly speaking, 'phase' is not properly a property of reactance itself.... Anyway - good work!:)
    @RRITESH KAKKAR
    Inasmuch as this thread represents @The Electrician 's approach to instructing you, I hesitate to 'interfere' beyond 'the superficial' -- Please understand that trial of truly diverse technique is in your best interest:)
    Best regards
    HP
  5. The Electrician
    Oct 9, 2007
    2,301
    339
    That is exactly correct. Notice that the voltage source Vs is only supplying 10 volts, but you have 60 volts appearing across the inductor. This is what a series resonant circuit can do for us. It is an important phenomenon that we can use for impedance matching.
    Now, can you calculate the Thevenin equivalent impedance appearing at node 3? That will be the impedance at node 3 when the voltage source is replaced with a short circuit.
    RRITESH KAKKAR likes this.
  6. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    The total impedance by shoring the Voltage source and open node 3
    will give us:
    Z=√(R²+Xc²)
    Z=30.41ohm, right?
  7. The Electrician
    Oct 9, 2007
    2,301
    339
    No. You have R1 and C1 in series, with that combination in parallel with L1, like this:
    What is the impedance seen at the A-B terminals? You will have a complex impedance, with a real and an imaginary part.
  8. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    OK,
    At 30.41ohm // with L1 30ohm
    Z=1/(30.41²+30²)
    Z=42.7ohm may be.
  9. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    (5-30j) // (0+30j)
    (5-30j)*(0+30j)/ (5-30j)+(0+30j)
    (5-30j)*(0+30j)/(5)
  10. The Electrician
    Oct 9, 2007
    2,301
    339
    Ok. I see your problem here, RRITESH. You are having difficulty working with complex impedances.
    I'm assuming you know how represent complex impedances using the imaginary constant j which is SQRT(-1). If you don't you should tell me so we can brush up on that technique.
    The impedance of the series combination of R1 and C1 is given by (5 - j 30) and the impedance of L1 is (0 + j 30), so you need to calculate (5 - j 30) || (0 + j 30)
    The impedance of the parallel combination is \frac {(5 - j 30)*(0 + j 30)}{(5 - j 30)+(0 + j 30)} , using the conventional product over the sum formula. Can you do this complex arithmetic?
  11. The Electrician
    Oct 9, 2007
    2,301
    339
    OK. But carry the multiplication in the numerator further, so you end up with an expression in the form A + j B.
  12. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    How to do?
  13. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    (5-30j) // (0+30j)
    (5-30j)*(0+30j)/(5)
    0+150j+0-900j²/5
    as j²=-1
    150j+900/5
    30j+180
    180+30j i think
  14. The Electrician
    Oct 9, 2007
    2,301
    339
    It's simple complex arithmetic. I think you must have forgotten how to do this.
    You do it the same way you would do it with real arithmetic. Do you remember how to do this:
    (a + b) * (c + d) = a*(c + d) + b*(c + d) = a*c +a*d + b*c + b*d
    Proceed in the same way with complex arithmetic:
    Code (Text):
    1. (5 - j30) * (0 + j30) =
    2. 5*(0 + j30) - j30*(0 + j30) =
    3. 5*0 + 5*j30 - j30*0 - j30*j30 =
    4. 0   +  j150 -  0    -  j*j*900 =
    5. In this next step it's very important to remember that j*j = -1
    6. 0   +  j150 -  0    - (-1)*900 =
    7.       900 + j150
    And finally, divide by 5 which was in the denominator:
    We get 180 + j30
    This is the Thevenin impedance seen at node 3 of the original circuit.
    Do you follow everything so far?
  15. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    I have also done the same thing above.
    Ok now what to do?
  16. The Electrician
    Oct 9, 2007
    2,301
    339
    I see that you worked it all out while I was preparing my response!
    Yes, you have the correct result.
    Now, imagine that we wished to get rid of the imaginary part of that impedance. Since the imaginary part is j30, which is the reactance of an inductor, we see that if we placed a capacitor whose reactance is -j30 in series and to the right of node 3, after the capacitor we would see an impedance of 180 ohms, which is a pure resistance of 180 ohms. We would have a circuit like this (ignore the R2 designator):
    Do you understand why the impedance at node 4 would be 180 ohms?
  17. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Now i got it that because the reactive power and impedance has no use.
    Why we say it is imaginary??
  18. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Yes i understand importance of it.
  19. The Electrician
    Oct 9, 2007
    2,301
    339
    Well, actually reactive power has a use. It performs the impedance transformation we want to happen in this case, but in the end we want to get rid of it.
    Complex arithmetic first came into use because the mathematicians of a long time ago were trying to find a solution of this equation:
    X^2 = -1
    Since they knew that multiplying two negative numbers gave a positive result, they didn't understand how there could be a number X such that X*X = -1. It seemed that no matter what X was, X*X couldn't be negative. Thus the concept of SQRT(-1) was born, but it seemed mysterious and they called it "imaginary", with imaginary meaning "not real".
    Now we use the symbol j for SQRT(-1).
  20. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    ok, now what is next step?
Thread Status:
