Resoldering/reconnecting detached microusb
StevenMac
Joined Oct 5, 2013
I'm a complete newbie here and I'm hoping somebody can help me with the basic but tricky task of resoldering/reattaching a microusb that has become detached from its hard drive. I think the actual piece it's connected to is some kind of breakout controller board with a load of encryption/decryption stuff that means you can't use any other breakout board with it. Hence my attempt to try to reconnect, before going out and buying another HD that whose board may not work with my drive.
The connections are very, very small, and I'm wondering, is it better to try to solder a bunch of wires between the board and the microusb, rather than try to solder the microusb back to the board? How would people here do it?
Thank you in advance for any tips,
Steve.
GopherT
Joined Nov 23, 2012
8,009
When taking close ups, use a tripod or othe non-handheld support for your camera, use the delayed shutter feature and set camera to close up (flower icon). Make sure the "focus brackets" are green, not red. If red, move the camera back a bit. Use maximum resolution.
