Resistors
Discussion in 'Marketplace' started by Markd77, Jan 18, 2011.
Thread Status:
Not open for further replies.
  1. Markd77
    Thread Starter Senior Member
    Sep 7, 2009
    2,803
    594
    I'll start the ball rolling, a selection of surface mount resistors and a couple of values of surface mount capacitors.
    I'll never use more than half of them so 50 of each value are up for grabs (as a set, not much point splitting them).
    Will swap for any unwanted PICs or LEDs or other interesting stuff.
    Code ( (Unknown Language)):
    1. Pk 100 22pf 0805 50v npo cap. (rc)
    2. pk 100 1n 0805 50v x7r cap. (rc)
    3. 22R 0603 1% Chip Resistor Pk 100
    4. 33R 0603 1% Chip Resistor Pk 100
    5. 47R 0603 1% Chip Resistor Pk 100
    6. 68R 0603 1% Chip Resistor Pk 100
    7. 100R 0603 1% Chip Resistor Pk 100
    8. 160R 0603 1% Chip Resistor Pk 100
    9. 220R 0603 1% Chip Resistor Pk 100
    10. 100r 1206 5% chip resist.(100) (rc)
    11. 270r 1206 5% chip resistor(100) rc
    12. 360r 0603 5% chip resistor (100) (rc)
    13. 510r 0603 5% chip resistor (100) (rc)
    14. 750r 0603 5% chip resistor (100) (rc)
    15. 1k 0603 5% chip resistor (100) (rc)
    16. 1k6 0603 5% chip resistor (100) (rc)
    17. 2k 0603 5% chip resistor (100) (rc)
    18. 3k 0603 5% chip resistor (100) (rc)
    19. 4k7 0603 5% chip resistor (100) (rc)
    20. 10k 0603 5% chip resistor (100) (rc)
    21. 13k 0603 5% chip resistor (100) (rc)
    22. 22k 0603 5% chip resistor (100) (rc)
    23. 27k 0603 5% chip resistor (100) (rc)
    24. 47k 0603 5% chip resistor (100) (rc)
    25. 91k 0603 5% chip resistor (100) (rc)
    26. 130k 0603 5% chip resistor (100) (rc)
    27. 240k 0603 5% chip resistor (100) (rc)
    28. 360k 0603 5% chip resistor (100) (rc)
    29. 510k 0603 5% chip resistor (100) (rc)
    30. 820k 0603 5% chip resistor (100) (rc)
    31. 2m2 0603 5% chip resistor (100) (rc)
    32. 10m 0603 5% chip resistor (100) (rc)
    33. pk 100 10r 0603 1% chip resistor (rc)
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Congrats, you are the first to appear in the new forum. Good luck
  3. tom66
    May 9, 2009
    2,613
    214
    I wouldn't mind building up my SMT resistors collection...
    How much for all the E12's?
    10, 12, 15, 18, 22, 27, 33, 39, 47, 56, 68, 82 and all multiples to 1 meg-ohm.
    If you want, I have some axial resistors, packs of 100 of all E12 up to 1M (maximum 20 each though, as I need them for other projects), I also have money ;).
  4. Georacer
    Nov 25, 2009
    5,151
    1,266
    I think money should be left out of this forum. The risk of us becoming a front for under-the-table transactions is somewhat imminent.
    (is imminent used correctly?)
  5. jpanhalt
    Jan 18, 2008
    5,699
    909
    Agree. I think it is best to handle the money by PM.
    John
  6. Markd77
    Sep 7, 2009
    2,803
    594
    I haven't got the full set, just the ones I listed.
    If you still want the lot I'd swap for 20 each of these ones that I'm running low on in axial.
    10,12,82,150,220,470,560,2.2k,3.9K,4.7K,5.6K,6.8K,10K,56K,68k,180k,1M
  7. tom66
    May 9, 2009
    2,613
    214
    I'll consider it, but I need to check what SMT resistors I have... I have a few 270 ohm, I think that's about it.
Thread Status:
