resistors
Discussion in 'General Electronics Chat' started by scoots2, Feb 1, 2007.
  1. scoots2
    Feb 1, 2007
    on my stero board when checking the resistors what would be the lowest on the amp meter to show it is bad have my stero that just quit it is not a fuse new at this any help will do the nearest repair place to me is 50 miles& a long wait
    thanks
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You will have to use an ohmmeter to check resistors. But, unless they show damage (discoloration or split body), it's much more likely something else is bad.
    You need to verify that all the power supply voltages are present - if you know what they are. Being able to inject a signal and follow it through with an oscilloscope would be helpful, too. Without a schematic, this can be quite a challenge.
  3. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
    Depending on the brand and model it may have a safety cutout that kills power if it detects the slightest problem in the amplifier.
    You may be able to order a schematic from the manufacturer.
  4. Gadget
    Jan 10, 2006
    613
    If its not the fuse, or the Power supply.... odds on bet that its the Output devices......
    Might be cheaper in the long run to take it that 50 miles, and put up with the long wait.
