resistors
Discussion in 'Homework Help' started by dlmcknny63, Jan 17, 2009.
  1. dlmcknny63
    May 25, 2008
    11
    a 4 ohm resistor is connected across a 12 volt battery.How much power will the resistor dissipate?
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  3. mik3
    Feb 4, 2008
    4,846
    63
    P=V*I or
    P=(V^2)/R or
    P=(I^2)*R
    where
    P=power in Watts
    V=voltage across the resistor in Volts
    I=current through the resistor in Amps
    R=resistance of the resistor in Ohms
    Choose one and make the calculation, the second one suits better in your case because you know the voltage across the resistor and R.
