Resistors in parallel
Discussion in 'Homework Help' started by tjjam2003, Sep 14, 2006.
  1. tjjam2003
    Apr 5, 2006
    22
    A 2700 Ohm, a 39k Ohm, and a 56k Ohm resistor are connected in parallel. If 5mA flows through the 56k Ohm resistor, how much current flows through the 39k resistor? This one has me stumped ! Can someone help?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Remember that I = E/R. The current through the 56K resistor will give you the voltage across it. In a parallel circuit, that same voltage is across every other circuit element. No problem solving for the other currents.
