I need to insert a low-value series resistor in the power trace of a PCB to monitor power consumed by a microprocessor IC. I will be using a 50 ohm 1% resistor. At a current of 5 mA, the drop across the resistor will be 250 mV. The processor requires a supply voltage of 3.3V. Question is, is it ok to increase the power supply voltage to 3.55 V to compensate for the resistor drop in order to maintain the proper supply voltage to the processor? If so, is there a general rule of thumb for how much the supply can be increased (e.g. if a larger value resistor were used)? I'm curious if there are any detrimental effects to the processor circuit by doing so. For instance (an extreme case), could I use a 1k resistor (Vdrop = 5V) and increase the power supply to 8.8V?
