Thank you, How do i disassemble the resistor?. May be like an onion?a really very weird colour markup . also no any online converter converts values properly
fuses definitely would not look like that
i think that this are resistors and i suggest you to replace them with bigger wattage rating ( looks like 1/2 - 1 w ) and if you know their values correctly ( and if you measured their values if they are not burned , because burnt resistor possesses less resistance ) . you can disassemble one of these elements to be sure , but i am sure that this are resistors
Thank you, going to open it.i meant " break it in the middle " . if there is not any wire on the dark ( ferromagnetic ) small " rod " , and its structure inside is monotone , then i think that this is a resistor in 99 % cases . quite simple
sorry broken english
