I am trying to understand the appropriate way to use a voltage divider to present a voltage to the ADC pin on an AVR microprocessor. The circuit is such that I have 5V coming through an ntc thermistor to a resistor and then to ground and the ADC pin is common to the point between the thermistor and the resistor. I believe the ADC is measuring the voltage across the resistor. I notice that with the thermistor that I am using, the value that I choose for the resistor will really affect my resolution at the low end and the high end. A low value resistor gives me much higher resolution at the high end whereas a high value resistor gives me much higher resolution at the low end. Is this a typical observation when doing something like this? Is it impossible to get high resolution at both ends?
