Resistor values for HCPL2630
Discussion in 'The Projects Forum' started by jm-a, Dec 12, 2010.
  1. jm-a
    Thread Starter Active Member
    Oct 20, 2010
    105
    Hi all
    I need to drive an IR2130 with HCPL outputs , and i have a few queries about it.
    Question 1:
    it's only for MC33035 Top drive outputs and Led.
    About HCPL otpo , what's the best choice, A or B, and why, only cost and place on board ?
    See " Choix-Resistances-HCPL2630-150x150.png "
    Question 2 :
    Now about MC33035 bottom drive output ( pin 19, 20 ,21 ) and HCPL Led.
    Bottom drive output values : High level 12,9 -----> 13 V
    Low level about 2 V Maxi
    Vf for this Led is 1,5V
    If = 15 mA maxi for High level
    If = 250 μA Low level
    Must i need to add 1N 4148 to be lower than 250 μA?
    I made ohm's law and found for only one resistor of 1500 Ohm:
    ( 2 -1,5) / 1500 = 333 μA from which question above.....
    Question 3:
    Is it mandatory to use a dc/dc converter to power HCPL2630 , or 7805 output will do the job?
    Thanks a lot, if anyone could reply me.....
    jm
