Resistor Size?
Discussion in 'General Electronics Chat' started by Rick A, Nov 10, 2010.
Thread Status:
Not open for further replies.
  1. Rick A
    Jul 30, 2010
    28
    This may be considered more of an elecrtic than electronic question, but I suspect someone here can answer it.
    I want to run a 95v 18a DC treadmill motor on 120v AC via a bridge rectifier. Can someone recommend the correct size resistor (ohms and watts) to cut the voltage down? Thank you.
    Rick A
  2. themindflayer
    Member
    Oct 29, 2010
    44
    18A is a lot of juice ..... apart from being a nice room heater the resistor doing the requested job will be huge, expensive and probably not available ..... also apart from the fact that resistors can not be used to regulate voltage .....
    do you have the said rectifier? 18A through the rectifiers will also be quite a lot ...
    IMHO what you suggest is not viable ....
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    For safety reasons, we can only insist you find a way to isolate the motor from the line. Not only can the motor not be run off a huge dropping resistor, but using no transformer will make it a lethal shock hazard, even if fused.
    If you can't find a 66 VAC transformer rated to 18 amps or a proper 95 volt power supply, then this is not a safe project.
Thread Status:
