Hi, I'm going to use a 2 digit 7 segment display (fed from a 4511 IC), and would like a confirmation on the correct size resistors to use. I will be using a 12 volt supply. The data sheet says:
http://www.nteinc.com/specs/3000to3099/pdf/nte3075.pdf
I'm thinking a 680 ohm smt resistor, but I'd like to be sure before ordering these.
thanks,
thanks,
