Resistor Question
BrandonNC
Joined Jun 10, 2012
7
Hello all,
Regarding resistor wattage; the LED calculators out there recommend that for a source voltage of 5V, a LED forward voltage of 2.6V, and a forward current of 28mA that I use a 1/8 W resistor. I am curious how they get this number? I thought it would be 0.14W, so rounding up to a 1/4 watt resistor?:
5V * 28mA = 0.14 W
Or am I suppose to use the voltage drop instead of the source voltage?:
(5V - 2.6V) * 28mA = 2.4 * 28mA = 0.06 W?
Thanks!
When calculating the power of a resistor you have to use the voltage drop across the resistor itself. Your second calculation is correct for the resistor power.
Your first calculation show the power supplied by the supply for this portion of the circuit, which is the power dissapated by the resistor as well as the power dissapated by the led.
