I have a circuit that I am trying to build again but in a surface mount configuration. I have a section or two that I need to jump to get this to work the way it is laid out. I saw the way resistors were laid out on this pre-biased transistor and it made me think.
http://www.onsemi.com/pub_link/Collateral/DTC114EET1-D.PDF
Part of the circuit is shown in the diagram below as Figure A. This is correct and working the way it is.
{Look at R3 - these are the only changes between figure A,B,C and D}
I would like to know if the figures B, C and D are acceptable also? It was not until I saw the data sheet above that raised these questions. This would solve a minor problem if and only if this is a correct way to accomplish what is in Figure A. I will try this again with the pre-biased transistors but this question is two basic in nature to ignore and not learn from.
Thanks for and wisdom and feedback!
