Resistor on a 48V charger?
Discussion in 'Power Electronics' started by kje, Jul 2, 2016.
  1. kje
    May 6, 2012
    20
    What kind of resistor do I need here? I know the capacitor on C6, but what number is on the resistor? R18? And ohm?
  2. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,511
    What happened to the original?
    Just guess work at this point without an identical board.!!
    Max.
  3. kje
    May 6, 2012
    20
    It's impossible to read anything from the original resistor as it blow up...
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    So you imagined that we could reach back in time AND read the mind of the original designer.
    MaxHeadRoom likes this.
  5. Dodgydave
    Jun 22, 2012
    5,147
    769
    Looks like its a smpsu, using a lm3???
  6. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Boy that was helpful!!
  7. crutschow
    Mar 14, 2008
    13,486
    3,371
    If you don't have any info on the circuit, then anything we say is pure guesswork.
  8. kje
    May 6, 2012
    20
    Ok. What should I do now? Can I test with a random resistor?
  9. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,511
    Do some reverse engineering of the circuit and it may be possible to suggest a value.
    Max.
  10. Papabravo
    Feb 24, 2006
    10,340
    1,850
    What @MaxHeadRoom means is that if you examine the board carefully you may be able to create a schematic. From that schematic, the design can be compared to similar designs, and the value of R18 can be determined with some level of precision. Are you up to the task? It won't be easy.
  11. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,511
    By the wire gauge and outline size and the proximity to the missing electrolytic, I would guess it is in the circuit in or around the power input /DC supply/bridge rectifier part of the charger.
    Max.
  12. kje
    May 6, 2012
    20
    Is it dangerous to try with a random resistor value?
  13. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,511
    It is much better to use an educated guess based on the reverse engineered part of the circuit, rather than 'Random selection'!
    Max.
