resistor notation
Discussion in 'General Electronics Chat' started by acelectr, Aug 28, 2010.
  1. acelectr
    Aug 28, 2010
    73
    Hi guys, im having a problem whit this resistance notation.
    for instance I know that 1k ohms mean 1000 ohms. but what does 1k5 ohms mean? what is with the 5 there:confused:?
    I'll appreciate any help.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    That is a 1500 ohm resistor, or 1.5K. The 1k5 form insures that the decimal point gets strongly indicated for less ambiguity. With faint print, it's hard to tell 1.5K from 15K.
  3. acelectr
    Aug 28, 2010
    73
    Thnx for your time :)
  4. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    beenthere is right.
    You can also see an R or M between the numbers:
    This quote comes from this page, with more info on resistor coding:
    http://www.diyaudioandvideo.com/Electronics/Color/
    This is a link from the EDUCYPEDIA page on component coding:
    http://www.educypedia.be/electronics/datacomponent.htm
    Bertus
