Hey,
I have question that needs to be solved. I have attached my attempt at the question. The first diagram is the resistor curcuit given and we are expected to find vout and current through Resistor R1 (labelled 1 on the dia)
I m unsure whether my approach is correct or not and I dont see if my method is correct to calculate vout and ir1 using the working done below.
Any suggestions/approach method needed to solve this would be helpful.
Another question regarding my working, if you notice I have ignored vout when doing his thevenin so can I ignore it ??
Thanks in advance for any help/ suggestions.
Matt.
Matt.
