Resistor measurement
Discussion in 'General Electronics Chat' started by Webby, Aug 11, 2008.
  1. Webby
    Thread Starter Active Member
    Jun 15, 2008
    66
    Hi, in a simple circuit with say three resistors wired in series (10ohm, 5ohm and a 15ohm resistor) if I open the circuit and attach my multimeter one end of the circuit to the other end should I beable to measure total resistance =30ohms?
  2. Audiofilo
    Member
    Jul 15, 2008
    13
    For resistance measurements you need close circuit, the multimeter send a current and then calculate resistance across voltage measured in.
    So, for get 30 ohms, from your circuit, you need measures in the ends.
    If you open, (and the ends are free) you can not measures anything (the multimeter will display OR, Over Range, say infinite resistance).
    Do not confuse resistance with impedance. The first is for DC, and second for AC, sometimes they are equal, but it is other theme.
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    If by opening the circuit you mean arranging it so only the resistors are being measured (no parallel paths), then you should be able to use a multimeter and see 30 ohms total resistance.
  4. Webby
    Jun 15, 2008
    66
    Hi thats what I thought....if its a series circuit with no parallel paths. Thanks for that info. Now im confused what "Audiofilo" meant?
  5. cumesoftware
    Apr 27, 2007
    1,330
    11
    I think that Audiofilo said thay you would need to create a "closed" circuit formed by the three resistors in series and the multimeter. That is a way to see things, and technically it is a closed circuit. Of course, the resistance of a resistor or association is always measured with at least one end of the resistor or association free, so eventual parallel components (parallel to the resistor or association, so to speak) that may exist in your circuit won't affect your measurement.
  6. silvrstring
    Mar 27, 2008
    159
    Webby, you are correct.
  7. Webby
    Jun 15, 2008
    66
    Hi all, thanks for your input, with a closed series circuit and using my meter across the circuit (parralel) would I be able to read a resistor value or only total resistor value being as there still connected to the rest of the circuit.
