Can someone explain what the "Limiting Element Voltage" (LEV) is for a resistor is? and how you determine if your circuit is exceeding that rating?
I was picking out a resistor to use in a circuit I have and came across this rating on the datasheet. I was specifically looking at a 0402 SMT resistor with a rating of 50V for the limiting element voltage.
Specifically in the attached circuit. As Vin could be up to 60V are R1 and R3 resistors being exposed to a voltage above their 50V rating? and as such I would need to find a resistor with a higher LEV voltage ????
OR (for example with R3) is it simply using ohms law V=IR where I=.01A and R=169 so V=1.69 which is less than 50V so its ok?
