Resistor lead diameter grumble
Discussion in 'General Electronics Chat' started by tracecom, Jun 22, 2013.
  1. tracecom
    Thread Starter AAC Fanatic!
    Apr 16, 2010
    3,878
    1,396
    I received an order today from a well known supplier. Some of the 1/4w resistors have what I consider to be "standard" lead diameter, i.e., ≈ .021", but others have what I consider to be cheap lead diameter, i.e., ≈ .013". The thinner ones are also shorter. Functionally, I suppose it doesn't matter (except for solderless breadboard use), but it "bugs" me.
    Would anyone else be bothered by this?
  2. #12
    Nov 30, 2010
    16,663
    7,307
    Yes. The fatitude of the wire is a key factor in the thermodynamics.
  3. tracecom
    Apr 16, 2010
    3,878
    1,396
    Well, that sent me to Google. :)
  4. #12
    Nov 30, 2010
    16,663
    7,307
    I thought a country boy like you would know that without any hesitation :D
    I only meant, "diameter", not what the google page says.
    (I didn't even know about the google definition.)
    Anyway, the mass of the connecting wire is a primary exit for heat.
  5. tracecom
    Apr 16, 2010
    3,878
    1,396
    Oh, so you were serious; there is a downside to the skinny wires.
  6. #12
    Nov 30, 2010
    16,663
    7,307
    Sorry. The silly button got away from me.:D
  7. THE_RB
    Feb 11, 2008
    5,435
    1,305
    I would not stress over it. They are just saving metal costs on what are basically obsolete parts now apart from hobby use.
    A 1/4W resistor would not be a good choice if you need to push the heat dissipation spec anyway, I would use 400mW metal film which are about the same package and mount size.
  8. Dr.killjoy
    Apr 28, 2013
    1,207
    157
  9. tubeguy
    Nov 3, 2012
    1,157
    197
    Yes, it bugs me.
    I also got some shorter-than-normal resistors which were a pain to use recently when they didn't reach as far as the original part.
    I received some T0-220 regulators where the 7815's had a tab that was
    about 1/2 the normal thickness. That was also a BIGGER pain 'cause the
    original shoulder washer didn't work without a slight modification.
    Oh Well...:)
  10. Ron H
    Apr 14, 2005
    7,050
    657
    Great word!:D
    I believe fatosity is another acceptable term for wire diameter.;)
  11. Duane P Wetick
    Apr 23, 2009
    408
    19
    This brings to mind a GE locomotive over-reaction when a locomotive would not start for world dignitaries all because of the failure of a 3 watt resistor. When I was shown the offending component, it was obvious (at least to me), the resistor maker decided to economize the leadouts due to the cost of copper and used a smaller wire size. Wire fatigue (or the other word) caused the problem so all locomotive resistors had to be 100% tested after this event. I think they went to fatter power resistor leadouts after this.
    Cheers, DPW [Everything has limitations...and I hate limitations.]
