resistor keeps buring out
Discussion in 'General Electronics Chat' started by ak52, Dec 31, 2014.
  1. ak52
    Oct 15, 2014
    145
    Hello Everyone,
    I need to convert a 12v supply from a lead acid battery to a 3.3v supply using a LM317
    I have given the connections as per the datasheet
    Where in my value of R2 is 390 ohm.
    I have added a 10 ohm resistor at the output for current limiting. and a 3.3v zenner.
    The moment I switch on supply the 10 ohm resistor burns out and soon after the zenner diode burns out as well.
    Where as the same circuit ,if i give the 12v from a regulated power supply it works perfectly.
    Should i use a high wattage resistor at the input side?
  2. blocco a spirale
    Jun 18, 2008
    1,461
    370
    What is the purpose of the 10R resistor and the 3.3V zener? Seems to negate the point of using a voltage regulator in the first place.
    What voltage is on the output of the 317?
  3. ak52
    Oct 15, 2014
    145
    The resistor and the zenner are just for precautions.
    The voltage at the regulator output is about 3.2 volts
  4. blocco a spirale
    Jun 18, 2008
    1,461
    370
    There must be something wrong if the resistor and zener are burning out when the supply output is only 3.2V. Have you actually measured the voltage across the 10R resistor?
  5. MikeML
    Oct 2, 2009
    5,451
    1,066
    What is the downstream load?
  6. ak52
    Oct 15, 2014
    145
    Yes i have measured it,but as i said before i have used two power sources here,
    With the regulated power supply (set to 12v) I get 3.2v
    But with the lead acid battery ,at the regulator the drop is 10v :(,which i don't understand as per the calculations mentioned in the data sheet it should come to 3.2v only.
    I am not giving any load at the moment.
  7. MikeML
    Oct 2, 2009
    5,451
    1,066
    Then you have the Zener backwards :(
  8. ak52
    Oct 15, 2014
    145
    Nope the zenner polarity is correct,i double checked,if the zenner is backward it should have burnt out with both power supply sources..
  9. blocco a spirale
    Jun 18, 2008
    1,461
    370
    Well, you've got something wrong. First, get the 317 working consistently, if you're getting different output voltages with different supplies there's a problem somewhere, maybe it's died or is connected wrong.
    All you can do is carefully and methodically check you work, assume nothing.
  10. GopherT
    Nov 23, 2012
    6,312
    4,031
    The
    The knee on a Zener is not very sharp on low voltage Zener diodes (below 5 volts is terrible and only really sharp over 8 volts). That is, you made a big problem by trying to solve a non-existant problem. Your 317 is good enough.
    http://www.microsemi.com/document-portal/doc_view/14614-zener-voltage-regulation-with-current
    cmartinez likes this.
  11. cmartinez
    Jan 17, 2007
    3,698
    2,788
    Why don't you use a buck regulator instead? An LM317 is rather inefficient in comparison
