Resistor Info
Discussion in 'General Electronics Chat' started by kbxc20, Jun 10, 2015.
  1. kbxc20
    May 27, 2015
    11
    Any one seen a resistor like this.
    0.47 ohm 2 watt I assume. However it powers a circuit that is 12 volt DC with a 1.21 amp load flowing thru this resistor.
    I can't see how this size resistor can carry this load unless someone knows otherwise.
    It blew along with a transistor. I replaced the transistor and this resistor with a wire wound 5 watt which blew from overloading.
    Other wise circuit seems to work ok.
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  3. ErnieM
    Apr 24, 2011
    7,443
    1,628
    1.21 amps thru a A .47 ohm resistor is just 1.21*1.21*.44=0.7 watts.
    So a 2 watt resistor should be quite fine here.
  4. kbxc20
    May 27, 2015
    11
    I get 14.52 watts 12Vx1.21A=14.52W
  5. ErnieM
    Apr 24, 2011
    7,443
    1,628
    I don't. Neither should you.
    If you put 12V across .47 ohms you get 25.5 amps.
    I assumed all of the current was going thru this resistor so the power is I*I*R
  6. kbxc20
    May 27, 2015
    11
    This is the amount of amperage flowing THRU the resistor, not as if you if you connected each end of the resistor to the power source.
  7. Veracohr
    Jan 3, 2011
    559
    77
    1.21A*.47Ω = .5687V across the resistor. Not 12V.
  8. WBahn
    Mar 31, 2012
    18,093
    4,918
    You are making the common mistake of throwing the nearest voltage and the nearest current at an equation just because it needs a voltage and a current.
    P = V·I requires the voltage across THAT device and the current through THAT device in order to determine the power dissipated by THAT device.
  9. kbxc20
    May 27, 2015
    11
    Thanks to all replies.
    But back to the original post. The values stated are actual operational measurements. The resistor is just in a series circuit with other components.
    All I know is that it now blows 5 watt wire wound ceramic case resistors after about 2 minutes
    whereas the one in the picture lasted for 4,745 hours. Again is this one made differently or is the current and voltage stated too
    high for the resistor in question. (see pic of disassembled resistor)
  10. WBahn
    Mar 31, 2012
    18,093
    4,918
    I would say that something has gone wrong with the circuit such that the "other components" that the resistor is in series with is now presenting a much lower effective resistance to the supply so that you are getting more voltage across (and hence current through) that resistor.
    What is the voltage measured directly across the resistor when it is in operation?
  11. kbxc20
    May 27, 2015
    11
    Ill have to get one and then measure
