Resistor in paralell...
Discussion in 'Homework Help' started by ESPguitar, Sep 25, 2005.
  1. ESPguitar
    May 15, 2005
    16
    Hi..
    I have a relay the coil is 960 Ω and i need to couple a resistor in paralell with this relay, the total resistance should be 1547,32 Ω..
    When i use the formula R2=(Rtot * R1) / (R1 - Rtot) i get this answer:
    R2= (1547,32 * 960) / (960 - 1547,32) = 1455427,2 / -587,32 = (-2529,161615)
    This ain't the right answer :S
    Can somebody help me with this (i guess it is a easy question for you but, you know:S)
    Thanks,
    Robin
  2. JoeJester
    Apr 26, 2005
    3,402
    1,221
    You have a coil with 960 Ω resistance.
    You have to couple a resistor to that coil to make the a total resistance of 1547.32
    Am I correct?
  3. Z2148
    Sep 21, 2005
    Are you sure that Rtot=1547.32 Ω and R1=960 Ω ?
    From what I know, Rtot should be smaller than the smallest resistance in the circuit when connected in parallel..
  4. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Correct, you can't have the above mentioned situation for two resistive devices in parallel. Either the numbers are wrong or there is an additional resistive element in series with the parallel network.
  5. aibelectronics
    Member
    Aug 26, 2005
    24
    unless you're using a faulty calculator that answer is impossible.
    Rtotal = Rcoil*R / (Rcoil+R)
    you can make R subject of formula. remember abs(Rcoil) = 2*3.142*freq*L
    what's your inductance?
  6. n9xv
    Jan 18, 2005
    329
    You must add a 580-Ohm resistor in series with the 960-Ohm coil. Assuming that 960-Ohms is the DC resistance.
  7. sanjeev203
    Sep 19, 2005
    7
    Robin,
    In relay, resistor always goes in series with the inductor consituting (RL+R) as total resistance.
    As other member suggested you, the equivalent resistance in parallel network is always lesser then the smallest one hence that has to be in series.
    I found a nice article for you.
    http://www.leachintl2.com/english/english2...erties/how8.htm
    Hope this will help you.
    Best regards,
    Sanjeev
