I have a 1 Ohm 50W 1% resistor and a 4 Ohm 50W 1% resistor with banana plugs on each end that are invaluable for measuring current. I got tired of blowing fuses in my DMM's when set to mA range. Much safer to measure voltage drop across a known resistance.I just happen to have a 3 Ohm, 50 Watt, 1% resistor sitting next to my keyboard. I pulled it out of... um... something or other a while back. I'll probably never use it. You want it? I can mail it to you.
by Aaron Carman
by Aaron Carman
by Aaron Carman
