Resistors seem a little counter intuitive to me but I understand how they work fine.
For example.
10vdc you wish to supply 100ma to the circuit, 10v/0.100= 100 ohms pretty straight forward, heat dissipation becomes 10v * 0.100 = 1watt you'd need a 1watt resistor or you'd risk burning it up.
But I don't see how that's the "resistor" resisting the voltage by turning the excess into heat, if you put 100ma through a wire, or anything conductive it's going to use create just as much amount of heat
So let's suppose that 100ma flowing through the circuit, if you stick a 1watt component rated at 10v into the equation, the resistor then should not produce any heat because it's no longer having to deal with 1watt of energy? I mean sticking a 10k resistor and next to no heat is produced and no way is that 10k resistor turning it into heat it would be cold as ice and supplying a little amount of energy....
(Resistors don't turn excess into heat unless nothing is there to eat up the energy?)
For example.
