Resistor Difficulty
Discussion in 'Electronics Resources' started by TotallyTwizted, Oct 6, 2014.
  1. TotallyTwizted
    Oct 6, 2014
    5
    Hello!
    I am having trouble deciphering the resistance of two resistors I am trying to replace. They are marked "3W0.5
    Ωk" Does the "k" mean that this is a kilohm value or does it have some other significance because it follows after the omega symbol?
    Help with this would be greatly appreciated!
  2. MrChips
    Oct 2, 2009
    12,627
    3,452
    A photo would help. Is this a big fat resistor? 0.5-ohm 3W is possible. Measure with an ohmmeter.
  3. TotallyTwizted
    Oct 6, 2014
    5
    They are pretty big resistors. They got fried up pretty bad (as shown in pic). Would an ohmmeter still be accurate on fried resistors? [​IMG]
  4. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    0.5 OHMs - I just know it
  5. TotallyTwizted
    Oct 6, 2014
    5
    Oki doke Thats good enough for me. Thanks!
  6. takao21203
    Apr 28, 2012
    3,578
    463
    just saying- normally nothing evaporates from these kinds. I guess it is some kind of glue which was just charred over time.
    They are still fine maybe. 0.5 Ohms is wirewound and they look differently after burnout.
  7. TotallyTwizted
    Oct 6, 2014
    5
    So these may be totally fine?
  8. MrChips
    Oct 2, 2009
    12,627
    3,452
    Your photo is badly out of focus. From what I can tell, the charred bit is not from the resistor but from some other plastic material that was resting on the two resistors. Those resistors have a ceramic body and it would take a lot of beating to be destroyed.
    A resistor overheating would be uniformly discolored. Those are not.
  9. takao21203
    Apr 28, 2012
    3,578
    463
    i'd say so, yes. Because if they are carbonized like that, there'd be more (visible) damage surrounding them.
  10. TotallyTwizted
    Oct 6, 2014
    5
    You two have been a big help! Sorry about the crappy photo, I'm not very good at using forums etc.
  11. kyle7119
    Member
    Feb 11, 2011
    71
    17
    I second this.
  12. takao21203
    Apr 28, 2012
    3,578
    463
    useless post?
