Resistor colour code
Discussion in 'General Electronics Chat' started by coldbuffet, Jul 9, 2014.
  1. coldbuffet
    Jul 9, 2014
    Hi, I've tried a search on these forums and I couldn't find an answer to my question.
    I was wondering if resistor colour codes can begin with a black band?
    For example, does a 7000 ohm resistor ever get shown as the following:
    Black - Violet - Orange - Gold = 7000 ohm +-5%
    Black - Black - Violet - Orange - Gold = 7000 ohm +-5%
    Black - Violet - Black - Red - Gold = 7000 ohm +-5%
    as opposed to starting with non-black bands:
    Violet - Black - Black - Brown = 7000 ohm +-5%
    Also why would a manufacturer choose to represent 7000 ohm with a 4 band resistor as opposed to a 5 band resistor or vice versa?
    Thank you!
  2. Dodgydave
    Jun 22, 2012
    5,134
    767
    No i have never seen a resistor starting with zero, 6 bands are more accurate usually with temperature coefficient,
    so 7K 5% would be violet,black,black,brown, green.
  3. wayneh
    Sep 9, 2010
    12,368
    3,224
    Ditto. I don't think the first band is ever anything but the 1st significant figure of the resistance value. It would cause too much confusion otherwise.
  4. wmodavis
    Oct 23, 2010
    737
    150
    In usual number/value representation a leading zero is dropped because it does not convey any useful information just as in resistor color coding - no useful information represented by leading zero.
  5. alfacliff
    Dec 13, 2013
    2,449
    428
    have you checked it with an ohmeter? and reverse? the only things I have seen with a black first band are diodes.
  6. Alec_t
    Sep 17, 2013
    5,956
    1,132
    A sixth band can be black, designating temperature coefficient:
  7. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    There used to be plenty around with a single black band - 0 Ohm resistors.
    Apparently they were easier for through hole pick and place machines to handle than pre-formed wire links.
    SMD resistors are of course marked with numerical values - I vaguely recall having seen at one time or another; SMD resistors marked "0".
    It seems to me that starting a colour code for a resistor other than "0" with a black band would be pretty pointless (values less than 1 Ohm have gold or silver multiplier) - The blue bands on some resistors under certain lighting can look black.
    There's a small LED flashlight and jewellers loupe ready to hand on my bench for these situations.
