resistor circuit reduction
Discussion in 'General Electronics Chat' started by enorthcutt, Sep 26, 2012.
  1. enorthcutt
    Sep 26, 2012
    Similar or related question.........
    What principle determines that series resistors are reduced before parallel resistors in simplifying a resistor circuit.
    Our class worked an example of a complex circuit and the results are definitely different if you use parallel firs and then series, or parallel and parallel.
    I cnnot find a principle or law that explains the series first, parallel second procedure
  2. bountyhunter
    Sep 7, 2009
    2,498
    507
    Post in homework section.
